Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Changing time step size using TUI commands and journal files › Reply To: Changing time step size using TUI commands and journal files
vganore
To change the Time Step Size using the TUI command (for example, to 1), enter the following: /solve/set/time-step 1.0 When you use the following journal file, the Time Step Size is 0.2 for 10 Time Steps then 0.5 for another 10 Time steps. /solve/set/time-step 0.2 /solve/dual-time-iterate 10 30 /solve/set/time-step 0.5 /solve/dual-time-iterate 10 30
