Ansys Learning Forum Forums Discuss Simulation Electronics Push Excitations not working in dynamic link Reply To: Push Excitations not working in dynamic link
dushyant.marathe
Hi Philtran,
If you check Help documentation (Circuit Help PDF and HFSS help PDF) GainTotal, RealizedGain, S-parameters are not updated with Push excitation in Ansys HFSS.
Field quantities such as rE , nearETotal, magE and SystemGain are getting updated with push excitation from circuit to Ansys HFSS.
You should check System gain and System efficiency after push excitation in HFSS and check S-parameter with matched network from circuit simulation only. The S-parameters are not updated in HFSS after creating matching network in circuit.
Thanks
