Ansys Learning Forum Forums Discuss Simulation LS Dyna tensile test of hyperelastic material (instability after 200 percent strain) Reply To: tensile test of hyperelastic material (instability after 200 percent strain)
Pedram Samadian
Hi Wasif,
Why is stress nonzero for zero strain in the experimental data? You can find some tips below to improve your model predictions:
  • Use a finer and higher-quality mesh in regions of high deformation to avoid numerical instability.
  • Consider using fully integrated elements (type #16 shell with a hourglass type #8) to reduce numerical instability at large strains.
  • Reduce mass scaling if applicable to maintain stability without affecting results.
I hope this information helps.
Thanks,
Pedram
