Ansys Learning Forum Forums Installation and Licensing Ansys Products Visualise pathlines across periodic instances Reply To: Visualise pathlines across periodic instances
nicholas.bizinos
Oh, I found a solution on our customer support space. Was actually not aware of this facility. In any case it there does not seem to be a direct solution but seems to be a workaround, rotating mesh, appending case and data, fusing and repeating for all instances. A little bit of a mission unless there is a better solution in later release?
