Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › How to output Ansys AQWA 2024R1 pressure contour as .csv file in ? › Reply To: How to output Ansys AQWA 2024R1 pressure contour as .csv file in ?
Mike Pettit
This feature has been added in Release 2024 R2. Please update your installation, if possible, and then you will be able to export wave elevations and surface pressures to CSV file.
If you are restricted to an earlier version, you can use AqwaFlow to output wave properties at specified locations. Please refer to the AqwaFlow user guide for more information: https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/corp/v242/en/aqwa_flow/aqwa_flow_intro_chap.html
Mike
