Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Unexpected Periodic Deformation in 2-Way FSI Simulation with Constant Inlet Velo › Reply To: Unexpected Periodic Deformation in 2-Way FSI Simulation with Constant Inlet Velo
0.1mm diameter(?) and 0.5m/s flow speed with glycerin (which is pretty viscous) will give a fairly high pressure drop along the tube. How rigid is the box?
