Ansys Learning Forum Forums Discuss Simulation Fluids How to Save Defined Animations Along with the Final Case? Reply To: How to Save Defined Animations Along with the Final Case?
Rui.Li
Testcases.in:
/file/read-case-data Testcases.cas
/solve/initialize/initialize-flow
/display/set-window-layout 1
/display/animate define velocity-magnitude-animation
/display/animate set-options velocity-magnitude-animation frame-frequency 10 file-format binary
/display/animate set file-name velocity_animation.cxa
/display/animate initialize
/solve/animate objects create animation-1
/solve/animate objects create animation-2
/solve/iterate 500
/display/animate save velocity-magnitude-animation
/file/write-case-data Testcases_completed.cas.h5
/exit yes
