Ansys Learning Forum Forums Discuss Simulation Fluids Spray modeling Reply To: Spray modeling
sjohn
Water is entering at 26.85 C. Outlet backflow total temp is 26.85 C. Contour plot the mid-plane (cross section) ranges from -272 C to 4725 C, which are at the edges. The mass-average temperature at the mid-plane is -37.14 C.
The following physics are enabled - Multiphase (VOF, Implicit, Interface Modeling - Sharp, 2 phases with constant surface tension and surface tension force modeling enabled), Viscous(Laminar with Viscous Heating disabled)
