Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › Initial Velocity Generation › Reply To: Initial Velocity Generation
January 9, 2025 at 11:05 am
valerym.m5
in my model, the parameter PHASE:=0
EQ.0. Velocities applied immediately
but if I understand the calculation results correctly, then ls-dyna solves the problem with the parameter PHASE:=0 EQ.1. Velocities applied after dynamic relaxation.
and with this ls-dyna somehow independently calculates the period of dynamic relaxation and for some reason it also changes the amplitude/magnitude of the initial velocity that I set.
