Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Unstable outlet temp in stable DPM › Reply To: Unstable outlet temp in stable DPM
January 9, 2025 at 10:51 am
If you plot temperature contours to see how the temperature variation is behaving how does it look? Just because the input flow is steady it doesn't always mean the output is! Also check DPM concentration (read the definition) to make sure you're not overloading a region (ie if the spray cones overlap/interact).Â
