Ansys Learning Forum Forums Discuss Simulation LS Dyna Initial Velocity Generation Reply To: Initial Velocity Generation
valerym.m5
Dear Pedram,
I will definitely take advantage of your kind offer.
But first I would like to make sure that my assumptions are correct.
So:
1. I could not learn to regulate the recording of calculation results at the initial stage of using an explicit solver.
For some unknown reason, the program ignores my instructions and writes the calculation results “arbitrarily” – immediately after switching the solver type – in this model – about 0.02 seconds.
After 0.02 seconds, the results are recorded with a step “close” to the required step, but still not exactly to my requirements specified in the curve.
  •  I am interested in the calculation results at the initial moment of time – at the moment of impact of the load.
2. Since I couldn’t solve the 1st problem, I tried to use the command:
Velocity_Generation_Start_Time
Where, according to the documentation, you can set a “delay” in time for the initial velocity applied to the “rigid” body.
However, ls-dyna ignores any specified delay values ​​and the initial velocity is activated at the moment of switching from the implicit to the explicit solver.
3. Taking into account my unsuccessful attempts 1 and 2.
I decided to achieve the required delay in the time of application of the initial velocity by moving the falling load a distance that I calculated from the specified initial velocity of 1000 mm per second.
However, from the analysis of the solution I found that the initial velocity of the load is not 1000 mm per second, but 2567 mm per second!
0.00805664 sec is the time of motion of the rigid body
20.68639946 mm is the distance the rigid body has moved
2567.62117458 mm/sec is the constant speed of motion
If someone wants to get acquainted with my model – see the link below
https://drive.google.com/file/d/1jf3XCB1v87ImHqMO-PfN6SXNVcTPGAUT/view?usp=sharing
I will be very grateful for any advice – since in this case I have a stalemate.
I tried to solve this problem with other data – trying to understand possible patterns, and I was very surprised, since the initial speed given was different each time?!
Below is another example of the solution
timeUy
10.00000000.0000000
10.016828520.1738129
10.021549225.8324966
10.022872927.4195175
10.023862828.6061802
10.024841329.7792721
10.025808330.9385910
10.026764932.0844803
10.027710033.2173271
10.028643634.3369370
10.029566835.4437866
10.030479436.5377007
10.031381637.6189613
10.032273338.6876526
10.033154539.7442780
10.034025240.7885284
10.034886441.8205681
10.035738042.8409538
10.036579143.8493919
10.037410744.8462029
10.038232845.8315926
10.039045346.8054848
10.039848347.7680931
10.040641848.7197609
10.041426749.6601524
10.042202050.5898819
10.042968851.5088005
10.043726052.4171677
10.044475653.3149796
10.045215654.2024994
10.045947155.0797882
10.046670955.9469223
10.047385256.8037834
10.048091957.6509781
10.048790958.4884300
10.049481459.3161201
10.050164260.1341667
10.050838560.9428711
10.051505161.7423515
10.052164162.5323830
10.052816463.3134384
10.053460164.0852509
Dt0.0534601
D_Uy64.0852509
speed1198.7487
For the last solution, the initial speed was specified -2800 mm per second,
but in reality – according to the calculation – the speed was 1198 mm per second
