Ansys Learning Forum Forums Discuss Simulation Photonics S parameter sweep for ring modulator Reply To: S parameter sweep for ring modulator
GWANG
Hi l76124262,
Thank you for the post. You are right that the time variant s-parameter cannot be directly generated from FDTD, and you will need to reformat the data once you get it from the simulations. You can find the time variant s-parameter data format here: https://optics.ansys.com/hc/en-us/articles/360036618513-S-parameter-file-formats. To generate the data for a ring modulator, you can refer to this example: https://optics.ansys.com/hc/en-us/articles/360042322794-Ring-Modulator.Â
