Ansys Learning Forum › Forums › Discuss Simulation › Systems › Coupled field frictional thermal runaway › Reply To: Coupled field frictional thermal runaway
January 8, 2025 at 3:46 pm
Rotational velocity just produces centrifugal forces. It doesn't actually rotate a body. An axisymmetric body can't rotate out of plane to begin with. You probably need to create a full 360 degree model. The command ICROTATE will produce a relative velocity at the contact interfaces based on the radius, but just for a single rotational velocity. It can't be ramped. Â
