Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Error message when coupling ANSYS Fluent and Rocky › Reply To: Error message when coupling ANSYS Fluent and Rocky
January 8, 2025 at 2:15 pm
Lucas Bertollo Baggio
you .c file is in the correct place (cfd_coupling folder).
However, I just found a case where the libudf folder (with the compiled UDF) is also inside the cfd_coupling folder.
You can also check the Rocky User Manual, section 3.5.11.9.1.2.2. Support for UDMs and UDFs.
best regards,
Lucas
