Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › In CFD Post, I can not see mesh regions! 2024R2 › Reply To: In CFD Post, I can not see mesh regions! 2024R2
January 8, 2025 at 10:20 am
Hi, shin7
I dont think this is a bug in 2024 R2, as the option for turning  On or Off mesh regions, is available in 2024 R2 as well. The settings remain the same as with previous versions, and also CFD-Post loads mesh regions by default.
Can you try this:
Close the CFD post first. Then rename the .cfx file in your user profile folder. You can find .cfx file inside the "C:\Users\username" folder. Rename .cfx to .cfx_backup.Â
Now you can try opening CFD Post again and see if the issue remains.
