Ansys Learning Forum › Forums › Discuss Simulation › Fluids › species gradient calculation UDF error — can’t find the function › Reply To: species gradient calculation UDF error — can’t find the function
January 8, 2025 at 10:08 am
Check you're retaining all data, using the TUI command. Fluent doesn't keep all of the gradient values between iterations for RAM/efficiency reasons.
/solve/set/advanced/retain-temporary-solver-mem
Also, try running an iteration/timestep before running the UDF commands, not all data is available following initialisation, and you are messing with scalar gradients!
