Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Error related to Custom Update › Reply To: Error related to Custom Update
Harshvardhan
The second error message might be a clue to this issue. This type of error typically occurs in a programming context where a variable is used before it has been assigned a value. You may need to check the Custom Update script or settings to ensure that all variables are correctly initialized before they are used.
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
