Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Issue with calculating characteristic impedance for a superconductive cpw › Reply To: Issue with calculating characteristic impedance for a superconductive cpw
January 7, 2025 at 9:40 pm
Hi Maryam,Â
You can refer to the example in File-->Open examples..-->HFSS-->Transmission lines-->Â Coplanar_waveguide.aedt or coplanar_wg_w_ground.aedt.
Note there is a white paper attached with the project, which is a pdf file and can be found in the project manager.
Best regards,
Rong
