Ansys Learning Forum › Forums › Discuss Simulation › Fluids › convergence issue for transonic flow › Reply To: convergence issue for transonic flow
January 7, 2025 at 6:12 pm
Did you check that you are getting those values?
There could be several other reasons for this not to converge. Also, density-based solver is typically used for high Mach numbers. Pressure-based solver should work fine here, even for compressible flow.
