Ansys Learning Forum Forums Discuss Simulation Fluids convergence issue for transonic flow Reply To: convergence issue for transonic flow
vamshigundla003
No, my inlet is not supersonic the flow is reaching 0.918Mach with this the pressure ratio 0.58 according to isentropic equations which means my inlet velocity is 315m/s.
I have kept 1 atm as supersonic pressure and 0.58 atm as outlet pressure (1 atm as inlet pressure) and tried but still the solution is not converging
