Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Simulating DPM whose droplet material properties not available in database › Reply To: Simulating DPM whose droplet material properties not available in database
January 7, 2025 at 11:37 am
If the flow is due to the pressure field you'll need to do a loop over the inlet and sum the mass flow: be aware that's a parallel operation so some caution is required. It's not a single "value" as the UDFs work on the facets and not surface.
