Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Named selections, scripting and modification of holes position on a plate: reg › Reply To: Named selections, scripting and modification of holes position on a plate: reg
mohan.urs
Hey,
The operations you have mentioned might all be possible through parameters as well although not directly but i definitely see a way.
But like you mention it will be easier through scripting. Like Harsh mentioned browse through Developer forum to see if there are any relative posts.
There is another option in spaceclaim - Scripting - which records the operations you do inside the software. You could utilise this to find out the right functions to move and place your holes. Explore the help link to know more about it.
Mohan Urs
