Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Named selections, scripting and modification of holes position on a plate: reg › Reply To: Named selections, scripting and modification of holes position on a plate: reg
Thank you for the guidance Mohan. I will attempt these option and will revert back.
Further, when i will be scaling for different point masses at different location on the same plate, for each point mass I want to use a excel sheet to define the coordinates of the centre of the interface circle, the diameter and extrusion.
I understand that i have to assign one reference coordinate system about which the above coordinates will be defined.
I think defining in the script will be better for assigning.
Please share your thoughts on this approach.
