Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Floating Point Exception- Multiphase Flow – Fluent › Reply To: Floating Point Exception- Multiphase Flow – Fluent
If you check the residuals you'll probably find the solution has diverged. Assuming you've done the tutorials, work through the mesh, model settings, time step, material properties and boundary conditions in roughly that order to figure out what's going on.
