Ansys Learning Forum Forums Discuss Simulation Fluids Applying the DEFINE_HEAT_FLUX udf Reply To: Applying the DEFINE_HEAT_FLUX udf
You may want to read the section in the manual covering DEFINE_HEAT_FLUX I suspect it's not the function you're looking for, and isn't hooked into the wall bc.
