Ansys Learning Forum Forums Discuss Simulation General Mechanical How to extract running loads and moments from SHELL181 elements in workbench? Reply To: How to extract running loads and moments from SHELL181 elements in workbench?
lolboomepic
Thank you, that helps a ton! One thing I'm confused about is the units and making sure I know what this is outputting. I've researched a bit and see that SMISC is usually for stresses? With no units, I'm not sure if this is load, load/length or stress. I doubt it's stress by looking at the stress contours and these values not being close, but I'm not sure if this is lb or lb/in?Â
