Ansys Learning Forum Forums Discuss Simulation Fluids HET_RXN_RATE UDF Reply To: HET_RXN_RATE UDF
That should be phase 0.
Once you've got that working you may find getting the phase transfer to be an issue as you're likely not going to have a clean interface between liquid and gas. You may need to switch to Mixture or Eulerian multiphase models.
