Ansys Learning Forum › Forums › Discuss Simulation › Electronics › how to simulate long circuits using symmetry advantage › Reply To: how to simulate long circuits using symmetry advantage
January 6, 2025 at 10:41 am
Praneeth
I am not sure why you want to kee the maximum mesh size as 0.2mm. Is it recommended by any expert?
The general recommendation would be to use the default adaptive meshing which gives the accurate result. If the adaptive passes did not converge, then you could increase the maximum number of passes.
Best regards,
Praneeth.
