Innovation Space Logo
FREE STUDENT SOFTWARE Login
  • Community
  • Learning
  • Support
  • Educator
  • Career
  • Maker
  • AnsysGPT
  • Learning Forum
Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › MAPDL is unable to connect to the system coupling › Reply To: MAPDL is unable to connect to the system coupling
January 6, 2025 at 9:49 am
Harshvardhan
Here is a FAQ similar to your problem:
When I start a System Coupling analysis, I get error messages similar to the following (but maybe with a different port number): CFX: — ERROR #001100279 has occurred in subroutine ErrAction. Message: ANSYS CFX is unable to connect to the system coupling service on 0.0.0.0 through port 49755. Please ensure that the host name and the port number are correct. Mechanical: — *** FATAL *** CP = 1.388 TIME= 13:45:41 MAPDL is unable to connect to the system coupling service on 0.0.0.0 through port 49755. Please check ANSYS execution options -schost and -scport for a System Coupling analysis and ensure that the host name and the port number are correct. I checked that the port is not blocked by my firewall. What could be the reason for the failure? | Ansys Knowledge
I hope this helps.
Harshvardhan
Ansys Help
Ansys Learning Forum (Rules & Guidelines)
Connect with Ansys
  • Legal Notice
  • Privacy Notice
  • Cookie Policy
  • Export Compliance
  • Terms and Conditions
  • Report Piracy
  • Forum Rules & Guidelines
  • Site Map
© 2025 Copyright ANSYS, Inc
Please Login to Report Topic
Please Login to Share Feed
Harshvardhan
Cancel Save Reply as Draft Publish
Edit Discussion
Avatar
Harshvardhan
Add Tags
Cancel Save Draft Publish
You are navigating away from the AIS Discovery experience
Proceed
Continue
Ansys Assistant
Welcome to Ansys Assistant!
Login
Ansys Commercial Customers: Go to AnsysGPT
Your chat history is not stored
Hey there, you are quite inquisitive!
You have hit your hourly question limit.
Please retry after '10' minutes.
For questions, please reach out to ansyslearn@ansys.com.
RETRY
Are you sure you want to leave? The window will be closed.
OK
