Ansys Learning Forum › Forums › Discuss Simulation › Fluids › The Relationship Between Steady Flow Iterations and Transient DPM Time Step › Reply To: The Relationship Between Steady Flow Iterations and Transient DPM Time Step
luna6362
Is this the setting you mentioned earlier? (Apologies for the picture quality)
I cancelled the Flow in Equations box.
Yes, you're right. There are always mishaps when creating an animation.😆 Thank you for the reminder!
I still have some questions about DPM.
  1. How can I determine which moment of the particle motion corresponds to the images at the iteration?
  2. Is the particle number for the face injection still calculated using the mesh of the face when employing transient DPM? (I only learned that the answer is yes when using steady DPM)
Thank you so much!
