Ansys Learning Forum Forums Discuss Simulation General Mechanical Help to do quasistatic analysis in static structural module Reply To: Help to do quasistatic analysis in static structural module
mhannan
if you see the part choroid, this part should change it’s volume overtime with the changing of pressure which are exerted by the 18 nodes by using nodal pressure. And the part called inside is actually vitrious body which is fully incompressible(So I modeled as water) when the choroid changes it’s volume, it’ll affect vitrious body and as it can’t change it’s volume it’ll create an opposite pressure to resist it’s volume deformity. I need to extract the pressure. Below part is the modeling of the opposite pressure which is named OPA in FEBio:
”To estimate the OPA in all models, a ‘‘volume constraint’’
 was imposed on the inner limiting membrane and the
 augmented Lagrangian was turned on. The tolerance and
 penalty factor were set as 0.00001 and 0.001, respectively.
 Those values were chosen because they maintained the
 volume of the vitreous within 0.000001% during the cardiac
 cycle. All pressure estimates (to maintain the volume of the
 vitreous body constant) were extracted from the FEBio output
 log file (.log) under the section ‘‘Volume Constraint’’ at each
 converged step.”
here is the ipdated model
https://drive.google.com/drive/folders/19FQFr4y9Cpfm5TyeTlqGjdfvhFeVS1jQ?usp=sharing
Also please check me the APDL, and can yopu tell me how can insert effective permeability.
I need your help badly, please reply me soon.
thanks in advance.
