Ansys Learning Forum Forums Installation and Licensing Ansys Products Remote Displacement for 3D Ball/Sphere (Solid Deformable) Reply To: Remote Displacement for 3D Ball/Sphere (Solid Deformable)
ashish.khemka
What is the error message you see when using the outer surface of the ball for remote point definition? I am assuming that you are defining contacts as well using the same surface and it might be conflicting with the remote point definition. For the first approach - it seems you are using half-symmetry. What is the reason that you doubt that results might be incorrect?
Ashish Khemka
