Ansys Learning Forum › Forums › Discuss Simulation › Embedded Software › How to use `$@$` as input operator of iterator(e.g. map)? › Reply To: How to use `$@$` as input operator of iterator(e.g. map)?
January 3, 2025 at 1:38 pm
It is not possible to use directly the concatenation operator through an iterator. But you can through an intermediate operator. Here is the piece of code that should match your need:
function mapOp(arr1,arr2: int8 ^ 2 ^ 3) returns (oarr: int8 ^ 4 ^ 3)
   oarr = (map Op <<3>>)(arr1, arr2);
function #pragma kcg expand #end Op(i1, i2 : int8 ^2) returns (o : int8 ^4)
   o = i1 @ i2;
Hope this helps,
Benjamin
