Ansys Learning Forum Forums Discuss Simulation Fluids Coupling DPM and Eulerian Models in CFD Simulations Reply To: Coupling DPM and Eulerian Models in CFD Simulations
naderbluastrike
I have built an approach to solve this problem and I need your advice on it, I have split the geometry into to parts:
Part 1: represents the water spraying process which will be simulated and meshed firstly in a separate workbench task, and its results.
Part 2: represents the condensation part of the Ammonia using the Eulerian model, where the resulting water injection (flow from DPM part 1 simulation) is taken as input.
Is it a good approach? Does it solve the problem that I cannot activate the two models in the same simulation process?
