Ansys Learning Forum Forums Discuss Simulation Fluids Coupling DPM and Eulerian Models in CFD Simulations Reply To: Coupling DPM and Eulerian Models in CFD Simulations
naderbluastrike
I apologize if you misunderstood it, It is an evaporative condenser the ammonia enters steel pipes normally and gets cooled by the water sprayers. As you can see the geometry has been split with a plane because I am using a symmetry plane to reduce computational cost.
