Ansys Learning Forum Forums Discuss Simulation General Mechanical Edge/Boundary Stress Probe Between Two Bodies Reply To: Edge/Boundary Stress Probe Between Two Bodies
mohan.urs
Hey,
Check this knowledge article to understand why you get the error and possible workaround -
When I evaluate a result, why do I get the following error message : “You have a result that is attached to an entity shared by more than one body”? | Ansys Knowledge
If you scope it to nodes you will see 2 different values - 1 for material 1 and another for material 2 like below
If its an unshared node it would be something like this
I'm not sure if there is a way to visualise them both maybe other forum users can help point out a way. But the nodal probe will give you the 2 values which are the 2 extremes in the legend.
If you are used to scripting in mechanical - there is a way to print out the values atleast - Check this thread from the developers forum
How can I get the nodal result for a single material if the node is shared between two materials? — Community Forum
Mohan Urs
