Ansys Learning Forum Forums Projects & Partners Kampus Merdeka Heat transfer between two solids not working Reply To: Heat transfer between two solids not working
Please can you replot with node values off and on a plane cutting through the domain? You may need to alter the scale to see cooling depending on the set up.
