Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Post-Processing Consideration for Wave Port Excitations in Rectangular Waveguide › Reply To: Post-Processing Consideration for Wave Port Excitations in Rectangular Waveguide
Praneeth
Thank you for reaching out to the Ansys learning forum.
You are correct to use the 'do not renormalize' option for your model. If this is selected, Ansys HFSS software uses the calculated characteristic impedance of each excited mode as the normalizing impedance during the analysis.
If interested you can go through these free AIC courses on waveguides - Waveguide Simulation Using Ansys HFSS | Ansys Courses and Intro to Ansys HFSS | ANSYS Innovation Courses.
Best regards,
Praneeth.
