Ansys Learning Forum Forums Discuss Simulation LS Dyna Error 41434 (SOL+1434) Error encountered in SPH neighborhood search routine. Reply To: Error 41434 (SOL+1434) Error encountered in SPH neighborhood search routine.
2551450404
I also had the same problem in simulating the problem with sph on the mpp solver, and the same error was reported. Have you solved it?
