Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Maxwell circuit – PWM › Reply To: Maxwell circuit – PWM
I apologize for misunderstanding your question in my previous response. The VPWM source in Maxwell circuit provides a signal wave (sinusoidal), and does not output the Carrior (triangular) and PWM (pulse) signals.Â
Instead of Maxwell circuit editor, Twin Builder (Simplorer) is the way to build a circuit that explicitly generates a PWM signal. For example, the basic elements have a Comparator that compares a control signal generated by Sine Wave or a carrier signal generated by Triangular Wave, and generates a high output when the control signal exceeds the carrier signal, and a low output otherwise.
If you need more specific information on generating and comparing waveforms, please refer to the help section of Twin Builder or contact Ansys support.
Ansys Twin Builder 2024 R2 > Twin Builder Components > Basic Elements Library > Modeling with Block Diagrams > Signal Processing Blocks > Comparator
Ansys Twin Builder 2024 R2 - Comparator
