Ansys Learning Forum Forums Discuss Simulation Electronics Y wiring method and the start and end points of winding. Reply To: Y wiring method and the start and end points of winding.
mohammadevs9
I saw them but let to ask my question in another way. I got a 2D induction motor model from rmxprt. The default exitation of windings is voltage. I want to create an external circuit that be equal to default voltage exitation in maxwell. I draw the circuit and connected it to windings but the result is different from default of maxwell. what is the problem?
For example in voltage excitation for PhaseA we have: Stranded conductors, Initial current = 0 A, Resistance = 4.6218459 Ohm, Inductance = 0.0019265104H, The voltage equation: 310.26*sin(2*pi*50*time), Number of parallel branches = 2. The winding has 6 coils.
In external circuit, I have the circuit that shown in picture. I set the R and L as follows: R = 2/3*4.6218459Ohm, L = 2/3*0.0019265104H
thanks!
