Ansys Learning Forum Forums Discuss Simulation Photonics How to use code to obtain scanning results Reply To: How to use code to obtain scanning results
Kirill
Dear Subscriber,
You can plot your sweep results directly from the Parameter sweep utility. Additionally, I recommend reviewing the following articles: Creating parameter sweeps using a script and getsweepresult - Script command.
Please also check the results of your sweep in the Parameter Sweep utility to ensure everything is set up correctly.
Best regards,
Kirill
