Ansys Learning Forum › Forums › Discuss Simulation › General Mechanical › Timber frame shear wall using beam connections › Reply To: Timber frame shear wall using beam connections
mohan.urs
Hey,
The forum thread you have already linked seems to explain the best setup for your problem. Without seeing the model it is difficult to understand what might be going wrong in your model. So i would suggest you include pictures of your setup like mesh, BC and results which are not making sense so that it helps others to understand the problem and your model.
Mohan Urs
