Ansys Learning Forum Forums Discuss Simulation General Mechanical nCode Issue with corrupt results Reply To: nCode Issue with corrupt results
danielshaw
Your project is not correctly defined to send multiple results files to one DesignLife system.  From the attached image, you have results cell (#5) from systems H, J, and M linked to the solution cell (#5) of the DL system, but the Mechanical model cells (#4) are not shared.  Therefore, it is possible for the meshes to be different in each Mechanical system.  When using multiple results files, DL requires the meshes to be identical.  Even if the meshes appear to be consistent, Mechanical might have created different contact or surface effect elements or the mesh could be the same, but the node/element numbering could be different. To ensure compatibility with DL, the Mechanical systems must share their model cells.
