Ansys Learning Forum › Forums › Discuss Simulation › LS Dyna › the problem for ISPG › Reply To: the problem for ISPG
December 26, 2024 at 11:00 am
The issue might be related to the Ansys LS-DYNA version and the number of cores used.
Most ISPG development occurs in Ansys LS-DYNA V15.0 and later. Therefore, please use the latest development version or any version above V15.0.
ISPG solutions are not fully parallelized. Use one core if there is only one solder joint, and two cores if there are two solder joints.
