Ansys Learning Forum Forums Discuss Simulation Fluids unable to get velocity contour on plaque region Reply To: unable to get velocity contour on plaque region
Rahul
Once you create obstruction in the artery use boolean subtract to remove that much region from fluid domain.
Refer the following example:
1. Created obstruction in the pipe
2. Substract the obstruction from pipe and pipe will have a impression of it
and cross-section at obstruction will look like:
