Ansys Learning Forum › Forums › Discuss Simulation › Electronics › Change in rated speed while using RMxprt › Reply To: Change in rated speed while using RMxprt
December 24, 2024 at 12:35 am
GLUO
In constant torque mode, RMxprt prioritizes the rated torque command, 259 Nm here. Rated Speed is neglected after getting the torque command. The actual rated speed should be read from the actual torque vs speed curve at the rated voltage.
GL
