Ansys Learning Forum › Forums › Discuss Simulation › Fluids › Residual Convergence Challenges for Liquid Fraction in Wet Steam Ejector Flows › Reply To: Residual Convergence Challenges for Liquid Fraction in Wet Steam Ejector Flows
Alassedi
Thank you for your response. The model is steady-state. The issue appears to stem from a constraint on the liquid mass fraction, which is currently capped at 0.1. Could you please advise on how to redefine this limit to fall between 0.0 and 1.0 so that the simulation can accommodate the full range of physically expected values? Please note that the liquid mass fraction limit does not appear in Solution > Control > Limits...
