Ansys Learning Forum › Forums › Installation and Licensing › Ansys Products › Tutorial or Help for 2 way FSI › Reply To: Tutorial or Help for 2 way FSI
Paul Hutcheson
In the reference frame of the IR, the balls are not translating.
The animation you show shows motion in the absolute frame. You are not solving this problem in the absolute frame.
Your Mechanical setup should also reflect this. Only RZ should be free, the other 5 DOF should be fixed.
You can check if remeshing is sufficient indeed.
