Ansys Learning Forum Forums Discuss Simulation Fluids Simulation of a storage in a lake – Which tool should be used? Reply To: Simulation of a storage in a lake – Which tool should be used?
toni.calabrese
Could you explain me better what you mean with the second sentence? If I assume the following:
  1. storage does not move and does not change in shape;
  2. constant Temperature of lake (10°C), storage (80°C) and air (5°C) (let's assume the storage is floating and the top is in contact with air)
With these assumption Fluent is not able to calculate the thermal losses of the storage in stationary status?
